Can't Autoload my BRX
I know I'm late, but just getting to grips with my v24 builds…
Something has changed between v23 and v24 such that my BRX will no longer autoload. If I start a clean profile and set the support paths I can APPLOAD my application. However, if I arxload via an MNL file or try to 'AutoLoad' via the APPLOAD dialog, BricsCAD just hangs on startup.
Since I'm not even getting to the start of On_kInitAppMsg, I don't think it's my code per se. Is there any other reason why my app might not be able to load 'early' in the startup process?
Sounds like your still referencing BRX23 SDK, Try using this super cool dependency checker
0 -
Thanks - I already tried that - but if that were the case my BRX would not load under any circumstance. The fact that I can APPLOAD it and it works post BricsCAD startup suggests something in the startup sequnce is going awry.
0 -
could be the same issue as this
0 -
just to add, Usually, if you can’t step into On_kInitAppMsg, it’s a dependency issue.
I had one of my apps hang in bricscad, I had something wonky in OnIdleWinMsg, I changed my code to do something else and did not investigate further
0 -
But if it was a missing dependency, it would still be missing at APPLOAD no? This has been working since ~BricsCAD 15-ish. Literally all I did for this build was change the paths to the v24 SDK and rebuild - but it's quite hard to see what is happening in the startup. This is the last thing in the debug output before the hang:
"BRXDLL/register OdRx class tree extensions
BRXDLL/construction of static instances
BRXDLL/DllMain/DLL_PROCESS_ATTACH
BRXDLL/onLoadBrxDll
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxOpenObjects, local name = brxOO
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxAllObjects, local name = brxAO
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxVerbose, local name = brxVerbose
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxLogOn, local name = brxLogOn
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxLogOff, local name = brxLogOff
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxProfilerOn, local name = brxPOn
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxProfilerOff, local name = brxPOff
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxDbgOn, local name = brxDbgOn
BRXDLL/AcEdCommandStack::addCommand/group = BRX_DEV_HELPER, global name = brxDbgOff, local name = brxDbgOff"0 -
I found the issue after lots of back-and-forth in the debugger…
At the start of my app class constructor I had:
CMFCVisualManager::SetDefaultManager(RUNTIME_CLASS(CMFCVisualManagerWindows));
I can't even remember what I was fixing by adding this! However, moving it to On_kInitAppMsg solves the problem.
0 -
yay!
0
