Is it possible to show/highlight the objects with errors find with AUDIT?
Sometimes I run AUDIT and it finds a few errors. It can fix them automatically, but then I don't know where the errors were or how they got fixed.
This can be a bit of hassle. For instance, sometimes you have an AUDIT-error with regards to a hatch. BricsCAD fixes this but the hatch is then losing its boundary-connection.
Would be nice to have the option to show the errors found before fixing them.
DWG health shows the errors, but doesn't highlight them in the drawing?
  • When you run AUDIT it reports the issues found to the command line. This includes the handle of the object, shown inside brackets. You can search on this handle in the Structure browser, which also gives the option to select and zoom.
    Note this only works for graphical objects. It won't work with non-graphical objects, such as your layer definition table.
  • Thank you for your reply Jason! This really helps. Next time I'll try and find the error-causing parts with your solution.
  • It can fix them automatically, but then I don't know where the errors were or how they got fixed.
    Or (at least in the past), AUDIT with fix enabled, could mean that you miss 30-40% of your geometry from your IFC or RVT imports after AUDIT :)
