Making parametric screw/bolt block
Hi
I want to make a parametric block of screw or bolt that can change the diameter and/or length.
Any explain or example to learn how to do this will be blessed and welcome.
Regards.
0
Have a look at this I did not make it else would add authors name.
0 -
Thank you
I will learn how to make also
Regards,0
