What's happened to my commands?
I (we all) have been using standard abbreviated commands for decades. RO, C, CO, F, L, PL, F, TR and so on. I've just opened V25 for the first time today and the commands I'm being offered are bonkers. ROAMABLEROOTFINDER?? What?! CACHELAYOUT??Are you tripping BricCAD? I've never cached a layout in my life! Can someone please advise which particular setting needs adjusted here? Many Thanks!
Hello.
There are lots of commands and system variables available for customizing using the command line.
Here, most likely, it is about ROAMABLEROOTFOLDER and CACHELAYOUT
To have the commands to use abbreviations, these should be defined in the default.pgp file.
If RO is set as abbreviation for ROTATE, then, when typing RO at the command line, RO(ROTATE) will be the first item available.
1 -
You can control the command line suggested command's list via Autocomplete settings, for example, exclude variables if they are confusing:
1 -
What about Customize, Command Aliases?
Found in c:\Users\username\AppData\Roaming\Bricsys\BricsCAD\V21x64\en_US\Support\default.pgp
1 -
Thanks all. I am used to setting up custom commands. I like SS for SELECTSIMILAR for example, but I have never seen half of the autocomplete commands being offered today. I suspect there must be an issue with a missing default.pgp file, if I'm to guess.
I run a number of other customisations, so I suppose now is the time to create one specifically for commands.
Thanks again for the suggestions
0
