What's happened to my commands?
I (we all) have been using standard abbreviated commands for decades. RO, C, CO, F, L, PL, F, TR and so on. I've just opened V25 for the first time today and the commands I'm being offered are bonkers. ROAMABLEROOTFINDER?? What?! CACHELAYOUT??Are you tripping BricCAD? I've never cached a layout in my life! Can someone please advise which particular setting needs adjusted here? Many Thanks!
Hello.
There are lots of commands and system variables available for customizing using the command line.
Here, most likely, it is about ROAMABLEROOTFOLDER and CACHELAYOUT
To have the commands to use abbreviations, these should be defined in the default.pgp file.
If RO is set as abbreviation for ROTATE, then, when typing RO at the command line, RO(ROTATE) will be the first item available.
1 -
You can control the command line suggested command's list via Autocomplete settings, for example, exclude variables if they are confusing:
1 -
What about Customize, Command Aliases?
Found in c:\Users\username\AppData\Roaming\Bricsys\BricsCAD\V21x64\en_US\Support\default.pgp
1 -
Thanks all. I am used to setting up custom commands. I like SS for SELECTSIMILAR for example, but I have never seen half of the autocomplete commands being offered today. I suspect there must be an issue with a missing default.pgp file, if I'm to guess.
I run a number of other customisations, so I suppose now is the time to create one specifically for commands.
Thanks again for the suggestions
0 -
I have a problem with ALIASEDIT command where I change COPY command to C but when I used C command on the prompter invoice CIRCLE command, what happens?
0 -
the CIRCLE command is CI
0 -
By (longstanding) default C = Circle and CO = Copy
If you changed the command alias for Copy to C, did you also change the command alias for circle to something else than C? Otherwise it will use the first occurrence of the alias which would be C for circle.
Edit: I notice you did change the alias for Circle, misread the original post to be from CLICK_CLACK.
It should work, though I notice the copy command is in there with another alias CP. If it is still not working as intended then I suggest to file a support request.
0
