Break Lines - Feature Lines for a TIN Surface? (Civil Site Dev)
Hello! I'm a new user and wondering if there is a way to create and edit what was a 'feature line' in Civil 3D. I need to plot a cl of a drive aisle of a parking lot and the ability to assign elevations at particular vertices, then assign the slope of the line so it will autmatically set the elevations at vertices in between the two points. I hope this makes sense. I remember doing this in Civil 3D many years ago and hoping this same functionality is in BricsCAD.
  • I received some support via email on this. The object I was looking for is a STRING. Yay.
  • So, now that I have learned to create strings I have a few of questions.
    1. How do I control the radius of an arc while placing a string?
    2. How can I edit a string once it is created, especially elevations, grades, etc.?
Welcome!
It looks like you're new here. Sign in or register to get started.
Welcome!
