plot output path
I changed the Plot Output Path but my .plt files keep going to the original briscad folder.
  • Maybe whatever is in the plot configuration files (.pc3, .ctb things) is overriding the path setting.I think it takes precedence over printer settings, as I found when I tried to troubleshoot the plotter.Hope other people reap some benefit from the plot configuration strategy, for me it's just a pain.
  • Before trying to change Plot Output Path, I changed the path of Plot Style and my .ctb files are successfully saving to the new folder (not the same folder as attempt for Plot Output Path).
Welcome!
It looks like you're new here. Sign in or register to get started.
