How to extract and draw surface profiles ?
I'm new using BricsCAD and I would like to know if there is any internal command or lisp to draw profiles similar to this one. In civil 3d its easy to draw sections of a surface.
I mean to draw a profile from a surface or contour lines, defining a polyline or alignment. And show the profile with the terrain dimensions and the length of the axis.
Thanks you
Hello.
Currently, in Bricscad, only the geometry is available - the vertical alignment.
The table with numerical data is not yet implemented.For now, you could investigate the Civil Site Design plugin, which includes more civil design features.
0 -
Hi
Thank you very much, we have just bought TcpMDT. However I have started to develop a lisp that will allow me to extract the profile and make annotations similar as the ones in the picture.
When I have it, I will share you, I would like to develop a set of free and open source tools for users who use cad programs for civil / mining engineering.
I have already developed the first tool that allows to place coordinates in the frame of the viewport.
All will be available at github.
Thanks you
0 -
Bit late for the party but having been a user of Civil Site Design for years, and a programmer of commercial software, it will take you years to get close to the add on software, it just not a make the profiles but massive tools regarding road design. Multi lanes, roundabouts, bus bays, sight lines to mention a few, I recieved notification re a webinar about road driveway gradings the software re-does the surface model including the driveway parameters.
The cost will be quickly recouped in time savings, have a google for their Youtube videos they show the power of the software. Pretty sure you can download a trial version.
0 -
Hi.
here is a lisp to draw 3D polyline long section.
- draw a line or polyline on a tin surface that represent the needed cross section.
- use "TINPROJECT" command to drape the line\polyline to the TIN surface.
- use the lisp to draw the long section (command "LCS") from the draped line\polyline.
hope it will help.
aridzv.
1 -
@Samu38 : try https://www.bricsys.com/v26/launch?wistia_id=62t5vvvigm as per v26.1 for starters and work yourself forward using HELP (for example ).
I sincerely hope that section lines will one day support alignments as input or that labeling functionality is extended to vertical alignment views. Let's keep fingers crossed.
0
