Edit Mtext: possibility to prevent zooming out to full text area?
Hi all,
A small question regarding multi-line text editing. Does someone know if it is possible to prevent BricsCAD that when double-clicking a multiline-text object it zooms out to the whole text-object? Especially with larger text-objects with more text this is a little annoying because I have to zoom back in to edit the text with a good visibility.
0
Hi, set MTEXTFIXED variable to 0 or 1, this prevents zooming during text editing.
2 -
Thank you so much for the quick reply! The setting was set to 2 in the BETA (standard), but now everything is back to 'normal' ;-)
0 -
You are welcome )
0
