Number of activations
Is it true that from V25.2 onward a single user license can be activated only on one computer (contrary to 2, as it was before)? I heard this from a nwesletter sent by country's Bricsys representative. Google still says 2:
But if you click on the link, product documentaion says only one:
If that's ture it's really discouraging for me, especially given it's a silent degradation of the software. I don't see it being mentioned in release notes, or even during purchase process. Please correct me if I am wrong.
It appears that this applies to licenses purchased after March 16, 2025. If you go to the EULA page and scroll to item #2 (Grant License), it's all in the 2nd paragraph of "Software Product".
0 -
It is indeed the case that if you purchase a single license, that you get a single activation, starting with the release of V25.2. In the past, even though it was possible to activate on 2 different machines, it was also already only allowed to be used by you as the primary user and for backup purposes.
This is also still listed in the EULA
"For singles licenses purchased before 17 March 2025: you keep the right to have a copy of the SOFTWARE PRODUCT on a second computer used by you, as the primary user. This additional copy is for backup purposes only and may not be used concurrently."0 -
is it possible to have the software installed on 2 computers,
one activated and one isn't,
and de-activate the one I'm using and activate the other?
for mexample,
I normally use desktop but when I'm on the road I want to use my laptop?
0 -
I think you can still install Bricscad on as many computers as you want …..
In the past you could activate that single license it on 2 Computers, are allowed to use it on one of them.
(AFAIR there was not really a mechanism to prevent you from using it on both - so I think that's the reason for possible new activation option changes)and de-activate the one I'm using and activate the other?
for mexample,
That would be much more cumbersome than in the past.
That tedious online deactivation was usually only needed when you had an new machine to replace one of the olders ….
And that deactivation/free Activation works only fine as long as you can access your machine.
Like when you buy a new machine you want to activate Bricscad - because your HDD/SSD died, Your Activation is lost - forever.
(For me it was once in the past that I completely lost a Linux Installation I used for testing, but unfortunately had Bricscad activated there for testing it on Linux)
In this case you have to ask Bricscad Support and beg for a another activation …..In the past with 2 activations you may still have access to the other activation when in deadlines - when there is only single activation now, you may better hope for relatively fast Support Request answers.
1 -
I do hope Bricsys re-considers that policy.
Even AutoCAD allows installation on second device (w/ non-concurrent usage).
I occasionally travel or do field work. Deactivating / activating licenses is burdensome.
2 -
Okay, the release of V25 first shattered my hopes of having these issues resolved, and now this dealbreaker downgrade of simultaneous activations… I guess I am never going to pay for an upgrade. Thanks Bricsys.
0 -
Really I don't see what the problem is (for Bricsys/Hexacon) if a paying customer wants to use Bricscad on a desktop at the office and also a laptop in the field or another desktop at home if the use is not "concurrent".
We switched to laptops last year so we can work on the road but would be nice if the option remained to use my desktop at home if said laptop got stolen, trampled by a rhino, or caught in a tornado. The license thing just keeps getting more confusing to me as I get older. How I miss the 1990's.
2 -
It would be really useful to be able to activate on two computers, desktop and laptop, as long as you don't use it concurrently. Desktops are generally more powerful than laptops but they're less convenient to take with you when not at your main location.
Not to mention that laptops are often more hardware limited than desktops. I don't want to worry about my laptop overheating when having to use really large files with lots of objects and it struggles to keep up where a desktop would work quite a bit better.
Having only one activation allowed would mean a lot of deactivating/activating over time, not that convenient. Not to mention if you accidentally forget to deactivate the desktop and are on the road with the laptop, then it becomes a major pain.
If Bricsys/Hexagon insists on only one active activation then they should seriously consider using a cloudbased activation system as Rhino 3D is using, you can install it on multiple computers (though in reality that would be a desktop and a laptop) and when starting up the software checks the license in the cloud and automatically activates on the machine that is in use and deactivates the other install. If you later use it on the 2nd machine then it automatically activates there and deactivates the previously used machine.
It seems there is a trend to reduce allowed installs on a second machine for business software, which only increases costs for the (smaller) end users on a single license if they need some flexibility with regard to being at the office or on the road. Or the accountants (aka bean counters) want to increase "shareholder value" by finding ways to force people to spend more. I hope they don't go the AutoCAD way where single users and small companies are becoming the kind of customer they can't be bothered about and only want big corporate clients.
4
