Bricscad v21, Wayland problem
I can't get Bricscad v21 to work in Wayland session, in Ubutnu 22.04: the software starts but gets stuck in a white screen.
Is there any way to fix this?
Thank you!
  • maxemilian
    edited March 2025
    yes there is a fix for waylan in the latest version if you glance release notes.
    https://boa.bricsys.com/common/releasenotes.jsp?i=9210
    but it might not fit your's issue.
    Hint
    Defining QT_QPA_PLATFORM=xcb in the .bashrc file partially solves wayland rendering X11 with QT apps. In my scenario didn't work for BricsCAD-V24.2.07-1-en_US-amd64 didn't tried on 21th version.
