Bricscad 25 no longer supports dots in command names?
In C# development for Bricscad 22, in the company we used command names with dots, as in: "NM.Version", "NM.Database.Tables" and so on, as in:
[CommandMethod("NM.Version", CommandFlags.UsePickSet)]
public static void Dev_Test3_Command()
We are changing to Bricscad 25, and we have an issue that the commands are visible in the command line, but the result is only an error message:
Unable to recognize command "NM.Version"
It appears that Bricscad 25 no longer supports dots in command names.
Is there a workaround around this? If not, we will have to undertake a major system update. :(
1
Does not work in AutoCAD either
from pyrx import Rx, Ge, Gi, Db, Ap, Ed, Ax, command @command def doit(): print(Db.SymUtilServices().validateCompatibleSymbolName("woohoo", True, False, False)) print(Db.SymUtilServices().validateCompatibleSymbolName("woo.hoo", True, False, False)) print(Db.SymUtilServices().repairPreExtendedSymbolName("woo.hoo", False))Command: DOIT
eOk
eInvalidInput
WOO_HOO0 -
- SOLVED
Sorry for posting this before I explored all the options. I tried registering the command using groupName and globalName, didn't expect that localizedNameId will do something. So here is the solution to this problem:
[CommandMethod(groupName: "NM", globalName: "MagicTruss", localizedNameId: "NM.MagicTruss", CommandFlags.UsePickSet, helpTopic: "wiki.nm.de/CAD/NM.MagicTruss")]
public static void JigTrussConstruction_Command()
This works.
1 - SOLVED
