Can I save a selection?
I want to select only single doors, I tried using SELECTSIMILAR, but even when its set to only select entities with similar Name, it selects all doors, even if they have a different Name, this does not seem to happen when using it on 2D blocks.
If I manually select the entities I want, can I save the selection for later use so that I dont have to manually select them again?
At the command line, enter (setq doors1 (ssget))
Select all the single doors, then Enter.
Any time you want to select all the single doors again, just use !doors1.
e.g. Move_!doors1_ or Selgrips_!doors1_That will only work while the drawing remains open.
You can use any name instead of doors1.To add to the selection set: use Selgrips_!doors1_ and then select whatever you want to add, and then enter (setq doors1 (ssget))
1 -
Thanks for the tip, it works fine, at first I guess I`ll forget the commands until I`ve used them a couple of times.
Strange if there is no easier way to save selections.
0 -
Groups are saved selection sets.
0 -
thank you! I will try it out, sounds like what I'm looking for.
0 -
quote: I guess I`ll forget the commands until I`ve used them a couple of times
You could make a pull-down menu command that does each of those things.
- Pull down Tools > Customize...
- Select the Menus tab.
- In the left pane, right-click on a menu and select Append item, or right-click on an item and select Insert item.
- In the pop-up, select the Create new tool radio button, then fill in whatever you want for the Title, and the following for the Command:
- For the command that creates the saved selection set: (setq doors1 (ssget))
- For the command that re-selects it: ^c^c_selgrips;!doors1;;1 -
clever! Haven't tried this before, will give this a shot to 😊
0 -
Anything that's repetitive and tedious can be automated with menu commands, toolbar tools, and lisp-based custom commands. For example, I very often want to rotate things 90, 180, or 270 degrees. So I have a custom command that rotates the selection set 90° for each press of a certain function key.
0
