Multiple button mouse with Bricscad
I am considering getting a multiple button mouse, like those being used in gaming. I have the impression that in those mice you can assign keyboard combinations to buttons. So, I suppose you could assign the combination L and then Enter, so in bricscad you would have the Line command with a mouse click.
Has anyone tried using such a mouse with Bricscad, and if yes, how is the user experience?
In combination with your new mouse, you might look into AutoHotKey
it’s magic, you can assign mouse and keyboard macros per application. I don’t do a lot of drawing work anymore. But for example,
#IfWinActive ahk_exe devenv.exe !o::send ^k^o ;toggle header/source Insert::send ^k^o ;toggle header/source Delete::send ^a^k^f{Esc} ;select all and format #IfWinActiveIf visual studio is the active application, ALT+O, insert and delete are reassigned. You could setup your mouse clicks to draw lines in BricsCAD, and Autokill in halo :)
1 -
Unfortunately Windows-only ….
I had (had - switches died 3 times) a 3DConnexion CADMouse, because of the physical middle mouse button.
You could define and apply all kind of shortcuts/macros/functions - per App. That worked very well. even for Bricscad's complex ACAD multi letter commands.Now I use a Logitech MX Master 3 for Mac. Its drivers aren't that perfect in general and do not allow such complex Bricscad Macros, but otherwise it works ok.
I had also used a MadCatz Gaming Mouse and loved it from a hardware standpoint. But unfortunately their Mac Drivers were deprecated quite soon and even for Windows there was no App specific configuration.Generally, a Mouse with driver support for "App specific" button assignments and macros is great - if it really works. So look closely at what is really supported for your desired input device.
0 -
Have you looked at Speach in windows 11 ? Standard type commands can be called, Line circle etc. Trying to find how to customise for defun names. Tested Some Commands Worked OK Done Using speech.
0 -
            I used to use a 5-button mouse. It worked fine with Bricscad. I eventually decided that the trouble of pressing those extra keys (on the side) wasn't worth it.I used to combine it with a macro handler, as Its_Alive suggested. I still use the macro handler (Macro Express), but I no longer use its mouse features. Some of what a macro handler does can be done with the Keyboard tab of Bricscad's Customize palette, but I use Macro Express with all apps, and love it.0
            I have had (as a spare now) a Corsair Scimitar Elite RGB with 10 buttons on the side.The main reason was to replace the scroll wheel clicks with one of the side buttons, but I had also configured some of the other buttons for commands in Bricscad. It turned out to be wrong quite often and since my hand often hurts I need to switch to a different mouse every now and then and I lose the function of these buttons. Now I use a macro keyboard (Halfmoon) together with Autohotkey0
            looking forward to the return of the digitiser.
Yes I have a Graphics pad and you can use a digitiser menu with it.0 -
            I have a Razer Basilisk v2. And use the buttons for some commands. I have micros set up for undo, escape, zoom all. It works great.
I second that motion for digitizer return.0
