Green dashed outline when pressing empty space
Hi,
Why does a "green dashed outline" appear when for example, I select the blank space inside the inner square?
The example below is when I have pressed mouse key at 1.
If I press at 2, the dash-dotted line will be outlined.
If I press at 3, everything is normal.
It´s a nuisance when I want to select an object or line, And miss. Instead this appears.
  • Mikael63
    edited April 2025
    How does it look likes when there is normal? (no mouse clicked)
  • What command are you executing when you pick point 1?
  • When there is no mouse clicked it all looks normal. Only when I click on "dead-space" inside a dash-dotted rectangle it does the outlines as in the picture.
    No real command, just a regular mouse click.
    Normal is?
    Like this?
    If by window select all, how does it looks?
    Is there any "wipeout" involved?
  • Normal is like this. 2 boxes overlapping.
    No wipeout involved.
    Just do demonstrate i drew an odd shape inside the dash-dotted lined.
    This is normal:
    Now i click inside the odd shape:
  • Could it be that the Boundary Detection command is activated?
    The bottom right icon in the attached image.
  • SOLVED:
    SELECTIONMODES did the trick!
    The Boundary Detection comment led me to another thread on the forum. Which had the solution.
    Thank you all for the comments!
