Selection cycling issue
Please can selection be permanently turned off?
When working with BricsCAD the selection cycling dialog always gets in the so I turn it of from the status bar or from the setting dialogue, but after a while the selection cycling starts to come up again despite the toggle being off on the status bar. Is this behaviour a bug or am I somehow toggling it on by mistake during selection?
Thank you for your assistance.
0
Are you turning it off in Settings?
1 -
I have experienced problems with the selection cycling, also if the Value=0;
I can not explain why, but after performing some commands the cycling popup reappears again, all thought it is set 0.0 -
This sounds like a known issue - when QUAD is used, Selection dialog box is still displayed even if it's turned off. This will be corrected.1
