Rotate the BimQuickDraw Plane
Somehow, I got the QuickDraw cursor facing vertical instead of on the slab. How did I do this, and how can I put it back so the walls get drawn going the right way?
There seems to be a dearth of info on people at my stage of learning drafting using this product. Or am I just looking in the wrong places?
Thanks for any help!
0
Probably this is a result of Dynamic UCS - Dynamic UCS - BricsCAD Lite & Pro | Bricsys Help Center0
by pressing shift You can change the orientation of the dyn ucs
1
