Attribute Drop list of values
in 2D Drafting
Dear All,
Is there any way to get a drop list of values for a bloc attribute without using lisp code. Maybe with a list of values contained in a parameter ?
TY
TY
0
You need to explain where is the list of attributes coming from. If you have say a string "x-xx-xxx-xxx" then yes could fill in 4 attributes. But again a lisp.0
Would this be of any use?
https://boa.bricsys.com/applications/a/?attributor-|-pick-lists-for-block-attributes-a1534-al25990
