Add vertex to Leader
The command is MLEADEREDITEXT.
We have a free resource that adds this to your right click menu. You can find it here.
https://www.cadconcepts.co.nz/resources/context-menusJason Bourhill
CAD Concepts Ltd
cadconcepts.co.nz2 -
Thanks Jason, really helpful0
Wanted to add to context menu, using CUI, Context menus, Insert item, Select available tool.Where can the command be found?0
There are several MLEADEREDITEXT command options as separate tools withing 'Available tool' list:
1 -
Thanks Lyubov, this is useful to know you can copy from the right.But unfortunately don't have "Multileader Add vertex at End".Version 24
0 -
Hi @sk11, it seems the MLEADEREDITEXT command options are missing in modern.cui in V24. Try to use classic.cui, you can switch to it via
1 -
Thanks Lyubov, but still the same when I use classic.cui
0 -
In BricsCAD V24 you should find it under Built-in\2D Editing in the list of available tools.
There is nothing stopping you creating your own tool with the same command. All the details to do so are given in the above image.
Jason Bourhill
CAD Concepts Ltd
1 -
Thanks Jason, I'll try that then
0
