SIMPLIFY command change z of polyline - CIVIL Topic
When I use Simplify command with few polylines that have z value the command chanche the z value of all of the polylines.
I want to use it to reduce the topographic contour lines that I extract from other software, that generate lot of points. Anyone have the same problem or knows why it happen?
Thanks you
