Work with "Body journal" like in Autocad
Hello, Is there any possibility to work with "Body journal" like in Autocad?
I mean working with the original 3D solids after using commands like UNION or SUBTRACT . In BricsCAD I have found undo step by step in the body history, but I can't select objects, only edges and faces of the resulting body
Example of workflow in autocad in attach:
0
In Bricscad as opposed to Autocad, there is not history kept for 3D solids !
Therefore you cannot select and modify the solids involved in a UNION or SUBTRACT operation…
Have a look at0 -
Ok, thx, it will take some time to adapt my workflow)
0
