Ctrl+F - select - get wrong Elements
Hi!
The button "Select" in the "Find and Replace dialog box" selects the wrong elements if the list ist sorted.
To reproduce this error:
- search for text: Ctrl+F
- enter some text an click "find"
- click on "Object Type" or "Text" to sort the list
- select some items in the sorted list and click on "Select"
>> the selected items in the drawing are not those selected in the list
Does anyone get the same result or is it just me?
I can't report this bug (if it is one) via support request because I don't have an active maintenance contract.
used BricsCAD: 25.2.07-2 German
System: Windows 11 Version 10.0.26100 Build 26100
  • Hi, yes, this problem has been reported by other user also, task is created for it.
  • Thanks for the answer.
    At least I know it's not my fault
