Etransmit dont packs the xref files?
Hey
Etransmit command packs me only the fonts files
I marked the "Bind" option in the dialog box , but it still dont packs the xref files.
Is this an error?
Regards
Meital.
0
Hello.
When using Bind, the attachments are bound inside the main drawing as internal blocks.
To keep the attachments as external files, the option "Bind external references" should be unchecked.
1 -
Thank you very much.
0
