Reactors !!??
Hi, I'm having a terrible time trying to figure out reactors. I've read multiple explanations and posts. But still not there. Can someone please have a look at my code and tell me what I've got wrong ?
;load visual lisp
(vl-load-com)
(setq myDrawingReactor nil)
(defun c:MakeSaveAlert ()
;access the application
(setq AcadApp (vlax-get-acad-object))
;drill down to open drawing (document)
(setq AcadDoc (vla-get-activedocument AcadApp))
(princ (strcat "\nCurrent Drawing is: " (vl-prin1-to-string AcadDoc)))
(attachDrawingSaveReactor)
) ;CALLBACK FUNCTION. THIS IS CALLED BY THE REACTOR
(defun mySaveCallback (reactor-object event-info /)
(princ "\n--- DRAWING IS BEING SAVED ! ---")
(princ)
;ATTACH THE REACTOR
;creat a reactor (defun attachDrawingSaveReactor ( AcadDoc / )
(if (not myDrawingReactor)
(progn
;create a reactor
(setq myDrawingReactor (vlr-dwg-reactor (list AcadDoc) "MyDrawingSaveReactorKey" '((:vlr-beginsave . mySaveCallback))))
(princ "\nDrawing Save Reactor ATTACHED to the current drawing!")
(princ "\nDrawing Save Reactor is ALREADY active.")
0
I just fixed it.
;load visual lisp
(vl-load-com)
(attachDrawingSaveReactor AcadDoc)
(defun mySaveCallback ()
(princ)
;ATTACH THE REACTOR
(progn
;create a reactor
(setq myDrawingReactor (vlr-dwg-reactor (list AcadDoc) '((:vlr-beginsave . mySaveCallback))))
)Now it works. I'm starting to understand reactors….
1 -
Atomkraft? Nein danke!
0 -
Not sure what your trying to achieve but I have "close and save" as reactors that run a certain defun before the actual save or close is ran. The defun does a task specific to a client request, manipulating title blocks.
0 -
I was basically just trying to get reactors working. All new to me.
0
