How to Needed: Compiling a LISP Main Program and Separate Support Files
Is it possible to compile both a main LISP program and LISP-specific file extensions that serve to provide key settings?
If not, what changes are required to compile the freely-available LISP program?
Specifics
In this case, it is an oldie but goodie, LayerCreator.lsp, that depends on a .lyr extension as a text-based support file or files (if various layer schemes are required) to hold key layer property variable and user-based settings.
Concern
I do not want our users to change the support file (.lyr) variables that represent company standard layers.
Attached
Main program & setup files (LayerCreator.zip)
Program readme & two .lyr files (Ascent Layers.zip)
Thanks,
Clint
If your running all your code off a server then you can lock the file edit to only certain users, whilst all others have read access. All our company stuff was on a server so only one version of a program existed.
In Acad you can make a VLX file which maybe can have your LYR files. Look up the help about making a BRX file similar to a VLX.
0 -
OK. We run off the cloud: No server.
I will explore BRX.
0 -
BRX uses a different programming language. For LISP in BricsCAD you can compile files to .DES format. It includes the option of including related resource files.
see
You can access the option to do this from BLADE
Jason Bourhill
CAD Concepts Ltd
1 -
Jason,
I have since tried this DEScoder LISP encryption and it met my needs. Plus, it was easy to understand and operate. Thanks Jason!
This user-friendly theme runs through all things BricsCAD, including the CUSTOMIZE environment. I feel it is a great way to corelate all aspects of customization in one dialog box. I quickly understood and am now applying customization loaded as a partial CUI how to introduce custom commands like never before.
Being less than adventurous/confident by nature, I never dared to try this type of activity for the years operating the other major CAD package. I felt I didn't focus as much as on CUIX mods as their approach made it all seem too fuzzy and not put together nearly as well.
Regards,
Clint
0
