eTransmit CTB file locked
in Other
Hi all,
My eTransmit settings aren't allowing me to change the CTB files in the Plot style tables dependencies. I cannot select them to delete them and add new ones. Any suggestions on why this is the case? Picture attached for reference.
0
Hello.
To change the ctb files, you need to edit the page setups.
Etransmit only allows you to select which dependencies will be included in the zip file.
In this case, the ctb files are missing, so they can't be selected for inclusion.
There is a notification about the missing files in the Transmittal Report.0
