Fix the plies at the nodes - strange v25 behaviour
Hi, I was testing fixing the plies at the nodes with v25 version.
The process is here described
I opened the daedalus project and tried to extend the concrete slab up to the brick wall.
Unfortunatly after the push/pull comand the slab is extended but the wall does not become subtracted.
By downloading the daedalus zip everyone can reproduce it.
Did v25 introduced any change on this regard that we should do to get proper plies at the nodes ?
AFAIR there is somewhere a Setting that controls if PushPull will subtract when overlapping other objects or not.
But you should be able to switch on the go with the CMD (Mac) or CTRL key in the PushPull options HUD at the bottom of the drawing window.
0 -
Great thanks.
It worked perfectly!
WOW! Bricscad bim has matured a lot!
Great piece of software here!0
