Importing Civil3D objects from current dwg - imports to different elevation
I am trying to import/convert Civil3D objects from the current drawing and for some reason the elevation is coming in incorrect. Example: one point should be 30.2 but comes in at 2.52. What may cause this?
  • Ah, nevermind. I notice the dwg units were set to inches, so of course when converting that causes issues. I changed to feet and now it converts just fine. :)
