Room schedule - BricsCAD BIM V25
Hi all,
I am learning how to create schedules using the BOM Manager. First I had a simple building with Room 1 and Room 2. I have generated the Schedule.
Then I divided Room 1, deleted that Space, created 2 new spaces and renamed them as Room 1 and Room 2. I also renamed the original Room 2 as Room 3 (I have changed their names too).
Now there is an empty row No.1 when I select it, everything exept the spaces is selected. I don´t know why… (is the original Room 1 stuck somewhere?)
I want to get rid of that empty row.
Any suggestions?
Thank you.
Hello.
First, you could check the filter set to the BOM, to see what types of entities are displayed.
Then, you could temporarily add a new column, like Type for example, to see what type is the extra entity displayed in the BOM.
To check the entire drawing structure, you could use the Structure panel.
The configuration of Structure panel could be set to bim.
You can change it to bim - Type to see all entities in the drawing by type.0 -
I have added the BIM → Type → Space column with filter set to "Space". I also made the column to be invisible. This works nicely.
Thank you.
0
