Make typed plans available to all projects
Hi,
Does anyone know where is typed plans support path?
It turns out that we have default typed plans already inside our suportfolder path here.
C:\Users\%%user%%\AppData\Roaming\Bricsys\BricsCAD\V25x64\en_US\Support\Bim\Typed Plans
But if you create a sheet nothing apears below typed plan.
I only have typed plans working if I place them on the project folder!
Can't we have typed plans common to all projects?
hi,
you can add typed plans to a project in the project browser on the files tab, with the blue plus button in the bottom right corner 'Import Typed Plan.
You can edit and create Typed plans in the support folder with TYPEDPLANS command that will bring up a dialog.
1 -
Hi Piet,
Great Thanks! But importing saves the typed plan on the project folder.
I was trying to make them available to all projects.Anyway I figured it out, so here is the solution for anyone with same problem
I discovered that if I copied the content of
C:\Users\%user%\AppData\Roaming\Bricsys\BricsCAD\V25x64\en_US\Support\Bim\Typed Plans
to
C:\Users\%user%\AppData\Roaming\Bricsys\BricsCAD\V25x64\en_US\Support\Bim\Sections\Customizations
it became available when I use the command TYPEDPLANS
So my conclusion is that the correct typed plans support path is Support\Bim\Sections\Customizations and not Support\Bim\Typed Plans ( bricsys placed the files on the wrong place )0
