Home UCS function ?
HI,
Is there a kind of "home ucs" tool in the lookfrom section like in Acad ?
If not, why ? It may be sometimes useful to quickly get back to a reference user view.
If yes, Where ?
Thanks.
Fredodb
0
Hi again,
I realize that saving views can make the job, but is there a dedicated tool ?
Thanks,
F.
0 -
If it's an orthographic view, then you could use UCSORTHO, which will work with the look from.
0 -
You can save a UCS, by doing just that.
UCS S Road1 then UCS R Road1 will return that UCS.
0 -
Thanks everybody.
Gonna try right now.
Nest regards,
Fred
0 -
Best regards… ;-)
0
