How to Create Collapsible Properties and Layers Panel
In AutoCAD, you can make a Layers panel and Properties panel, that are independent of one another, that open when you hover over the panel sidebar and then collapse when you move the mouse off the panel. I see that BricsCAD has LDOCK and RDOCK, that both collapse, but I don't see anyway to customize their content.
This would be extremely helpful because I have two monitors, with the BricsCAD main window open on the left screen and the properties and layer panel open on the right, but I will often times have a reference drawing on the right screen and it would be great if the layer/properties panel would collapse so I could see what is under them.
