BricsCAD BIM: Position of Doors/Windows within Wall Structure incorrect
When inserting a door/window into cavity wall using BIMInsert it is positioned on either the external face of the outer leaf or internal face of inner leaf. How can I get it to position correctly within the cavity/insulation layer? Any help is appreciated.
0
Hello.
The door and window components have a parameter named Placement Depth.
This parameter controls the distance from the inserting face on the wall to the frame.
You could experiment with this parameter and see it it is useful for your project.1 -
Problem solved. Thanks @Virgil for your help.
0
