BIM to 3dsmax: divide/split up a wall/floor/roof composition in parts?
Hey all,
I'm trying to think out a workflow from BricsCAD BIM to 3dsmax.
What I'm running into is that a wall with a composition (inner and outer material) is one solid object in 3dsmax. Thus, when assigning a material it is used for both the inside as well as the outside. Is there somehow a possibility in BricsCAD BIM to divide a wall/floor/roof composition into separate parts?
Are there any people here using a workflow from BricsCAD BIM to 3dsmax?
What, really? AFAIR that's not so in Twinmotion. The other day someone said that SketchUp surfaces are not 'proper' surfaces as they have two faces so that they can have different materials assigned.
0 -
Hmmm…not sure what I'm doing wrong with regards to twinmotion (via datasmith), because over there the same thing happens?
0 -
Right … maybe I haven't actually tried that. So - it's a real problem.
0
