Xline not plotting as expected in viewports
If I draw Xline's vertical and horizontal, the horizontal will be plotted differently if printed from paperspace tab. It will print the same when printed from modelspace. Is this a bug?
They look the same in modelspace and paperspace.
Edit: A Ray instead of a Xline prints as it should and you would expect.
Edit2: Deleting all and redoing them also works
0
So, this was related to some specific drawing or it can be reproduced in a new drawing also?
0
