Bug? Mtext gets deleted after UNDO command after text-editing
JorisHoogstede
edited November 19 in 2D Drafting
Running the latest V26 version.
When editing a text (contents/justification etc.) and exiting the editor and running the UNDO command the text-object is deleted. Not quite the behaviour when would expect 🤔
And even more strange…the AUTOSNAP marker setting is turned off after this behaviour.
Anyone else having these issues?
  • Hello.
    Indeed, it seems to be a bug in V26.1.06.
    The best approach would be to create a SR about it.
  • I forwarded this to developers, as it looks rather serious. But it would be useful to get such issues reported via Support Request indeed )
  • I file support requests always after posting here, because sometimes an error is due to a setting and not a bug. That way a forum post with solution is also visible to other users.
    @Lyubov Osina: since you forwarded it to developers there is no longer a need for me to report a support request?
  • Hi @JorisHoogstede, support request will add a value to the task, and you can track the issue easier. So I'd create it.
