Mtext typing issue using back slash
Using the 2026 version i noticed that typing in Mtext when i use a back slash, i am typing along and no spaces are showing up. the words look like this ….
ALL LOCATIONS TO BE SURVEYED /MEASUREDANDCONFIRMEDW/THETOWN
i get no spaces and a return does not go to next line after using a slash. Anyone else notice this or is it a me thing. Thanks
Confirmed, sometimes I notice such mtext behaviour (not permanent). In my case however, spaces were added but cursor was not automatically moved to the end of line. Pressing END key solves problem (but of course it shouldn’t be solved in this way).
0 -
Thanks, at first i though my keyboard space bar quit, guess i'll have to submit for a fix.
0 -
I can also reproduce the described behavior. Would you be so kind to create a Support request about this?
0 -
I will do a support request
0 -
This issue is known to them and will be fixed in the next update. Thanks all
0
