Exporting Section Views
Hi
My name is Robert and I don't know if im doing something wrong, but when I try to export a drawing with sections views generated by the new tool on v26, only get the line representing the surface but not the grid, the label with the SL #, the distance to the road axis or the height of the terrain. I attached 2 pictures, the first one with the sections before exporting and the second one after. I've tried to export using the option export to dwg and export to bricscad with the same result. I don't know if there some configuration I'm doing wrong or this is just Bricscad behaviour.
Have a look at …..
0 -
I saw the video several times, the problem is not while I'm working on a civil environment, it's after exporting the SL views to a regular 2D CAD drawing.
0 -
post a subset of the dwg file to explore !
0
