Replace window
I've placed a single-pane window in the building I'm modeling, but now, for design reasons, I need to replace it with a three-pane window. Is there a way to do this? Or do I just have to delete the incorrect window and place the new one, adjusting its dimensions and position all over again?
  • Insert the new Window Type somewhere in a Wall
    (To have that Block saved in your drawing)
    Select your old Window
    _blockreplace
    Select the new Window Type in your Block List
    Finally again a _BIMWINDOWUPDATE to update the Wall Opening
  • Thank you so much, I wasn't familiar with that command. I tried it, but I noticed it replaces all the blocks of that window. Is there a way to replace only the one I want, leaving the rest of the windows as they are?
  • Oh, I tested having a single Block Instance only - good to know. Wouldn't have expected replacing all instances.
    Doesn't make much sense to me. Usually I would select all Block instances I want to replace in that case.
    Unfrortunately I do not find any Options or Settings for BLOCKREPLACE.
