Visual style of active viewport in model space with lisp
Any ideas how to get it? through DXF codes? But I can't get the Viewport ID to be determined correctly.
To the best of my knowledge you cannot use the entmod function to modify a viewport entity !
by modifying the DXF code 281 (render mode/visual style) in the viewport entity list …..Render Mode Values Value DXF code 281 (Render mode)
0 2D Optimized (Classic 2D wireframe)
1 Wireframe
2 Hidden line
3 Flat shaded
4 Gouraud shaded
5 Flat shaded with wireframe
6 Gouraud shaded with wireframe: (setq vportData (entget (tblobjname "VPORT" "*ACTIVE")))
((-1 . <Entity name: 37e919c0>) (0 . "VPORT") (5 . "6F") (330 . <Entity name: 6b8d3180>) (100 . "AcDbSymbolTableRecord") (100 . "AcDbViewportTableRecord") (2 . "*Active") (70 . 0) (10 0.0 0.0 0.0) (11 0.320393657736 0.59083728278 0.0) (12 399.827504357857 253.38592012623 0.0) (13 0.0 0.0 0.0) (14 10.0 10.0 0.0) (15 10.0 10.0 0.0) (16 -0.491687877125855 1.19743813035916 0.56954802734165) (17 731.418796962038 498.457764863429 -221.616924238505) (40 . 280.841560210368) (41 . 1.5668449197849) (42 . 50.0) (43 . 0.0) (44 . 0.0) (50 . 0.0) (51 . 0.0) (71 . 0) (72 . 100) (73 . 1) (74 . 3) (75 . 0) (76 . 0) (77 . 0) (78 . 0) (281 . 4) (65 . 1) (110 0.0 0.0 0.0) (111 1.0 0.0 0.0) (112 0.0 1.0 0.0) (79 . 0) (146 . 0.0) (348 . <Entity name: 37e90cc0>) (60 . 3) (61 . 5) (292 . 0) (282 . 1) (141 . 0.0) (142 . 0.0) (63 . 250) (361 . <Entity name: 37e91c80>))ALTERNATIVELY …..
The ActiveX interface doesn't expose a property or method to deal with the visual style of a tiled ViewPort in model space either…
: (setq acadObj (vlax-get-acad-object)
doc (vla-get-ActiveDocument acadObj)
): (setq vportA (vla-get-ActiveViewport doc))#<VLA-OBJECT IAcadViewport 000000007A4F3E10>: (vlax-dump-object vportA T); IAcadViewport 7a4f3e10 : TeighaX Interface of a bounded area that displays some portion of a drawing's model space
; Property values :
; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000042687840>
; ArcSmoothness = 100
; Center = (399.827504357857 253.38592012623)
; Database (RO) = #<VLA-OBJECT IAcadDatabase 00000000A66BAD28>
; Direction = (-0.491687877125855 1.19743813035916 0.56954802734165)
; Document (RO) = #<VLA-OBJECT IAcadDocument 0000000074EB70B8>
; GridOn = 0
; Handle (RO) = "6F"
; HasExtensionDictionary (RO) = 0
; Height = 280.841560210368
; LowerLeftCorner (RO) = (0.0 0.0)
; Name = "*Active"
; ObjectID (RO) = 938023360
; ObjectID32 (RO) = 938023360
; ObjectName (RO) = "AcDbViewportTableRecord"
; OrthoOn = 0
; OwnerID (RO) = 1804415360
; OwnerID32 (RO) = 1804415360
; SnapBasePoint = (0.0 0.0)
; SnapOn = 0
; SnapRotationAngle = 0.0
; Target = (731.418796962038 498.457764863429 -221.616924238505)
; UCSIconAtOrigin = -1
; UCSIconOn = -1
; UpperRightCorner (RO) = (0.320393657736 0.59083728278)
; Width = 440.03517188008
; Methods supported :
; Delete ()
; Erase ()
; GetExtensionDictionary ()
; GetGridSpacing (2)
; GetSnapSpacing (2)
; GetXData (3)
; SetGridSpacing (2)
; SetSnapSpacing (2)
; SetView (1)
; SetXData (2)
; Split (1)So the best way seems to be to use the
in lisp code :
: VSCURRENT
Enter visual style [2dwireframe/Wireframe/Hidden/Realistic/Conceptual/Shaded/shaded with Edges/shades of Grey/SKetchy/X-ray/Other/cUrrent]: <2dWireframe>:(defun c:SetVPvisualStyle ( )
;; Directly sets the visual style of the active viewport
(command "_.VSCURRENT" "R")
(princ "\nViewport set to Realistic mode.")
(princ)
)2
