Block Attribute value vs Parameter from DesignTable
Dear All,
Is there any way to update automatically an attribute value of a block when modifying the value of a parameter (dropdown list made from a design table)
If the attribute value cannot be linked to the value of the parameter, can I insert a Mtext with a field in my block to get the selceted value of the parameter.
Would it be possible to concatenate 2 parameters values in this Mtext or attribute ?
TY
Hello.
Using parameters inside attributes is possible only when using regular parameters, which are of numeric type, not string type.
The drawback is that the formatting is not yet implemented, so there will be some trailing zeros displayed.
Using the UPDATEFIELD command is mandatory to update the value displayed by a field, the field values don't automatically update.If this is of interest, you could experiment with the category Field names > Extensions > Parameters.
0
