The graphic symbology for materials
The graphic symbology for materials in compositions is not showing up in my BIM models.
I have LOD and Render Composition selected but do not see the material symbology associated with the composition. This is clearly shown in the BIM Compositions list.
Can someone let me know what I need to do to resolve this?
  • Hello.
    If this is about the pattern appearance of materials in the 3D model, this appearance is displayed inside a section using Clip display = Yes.
    If it is about the 3D appearance, then RENDERCOMPOSITIONMATERIAL should be enabled, 1.
  • Thank you Virgil
