GUID format value different in BIMLIST & Properties Panel
Anyone know what GUID format is being displayed in Properties/BIM/GUID, it is not Standard GUID format, look similar to Base64.
But, BIMLIST on a selected BIM Profile reports Standard GUID format eg: {16D29523-A4A0-40D9-B87C-6466A5C40EA3}
Enter the Profile's GUID into a GUID format converter, there's no result of same value GUID
(assuming Base64)
0
Hello.
The compression algorithm seems to be like in the next article - see the function "compress".
0
