Adding a scale bar and north arrow linked to a viewport to paperspace
Is there any way of having a scale bar and a north arrow linked to a viewport, so they update based on standard scale and viewport rotation?
You could probably do this via .NET or BRX code. Not trivial though
0 -
Rotate north arrow. Change "Northn"
;; Rotate a block in pspace to match world in model
; By Alan H Aug 2020(defun c:roblknth ( / ss ssv obj ang layname x)
(foreach layname (Layoutlist)
(setvar 'ctab layname)
(command "._PSPACE")
(setq ssv (ssget "X" (list (cons 0 "VIEWPORT")(cons 410 (getvar 'ctab)))))
(if (= ssv nil)
(alert "No viewports found \nWill now exit ")
(repeat (setq x (sslength ssv))
(setq obj (vlax-ename->vla-object (ssname ssv (setq x (1- x)))))
(setq ang (vlax-get obj 'TwistAngle))
(setq ss (ssget "x" (list (cons 0 "INSERT")(cons 2 "Northn")(cons 410 (getvar 'ctab)))))
(if (= ss nil)
(princ)
(vla-put-rotation (vlax-ename->vla-object (ssname ss 0)) ang)
(princ)
(c:roblknth)Similar for scale bar read Customscale from Viewport properties and insert correct block etc.
1
