TEXTLAYER
Hi all,
is there any way to set a default layer for Text /Mtext in Bricscad?
The TEXTLAYER system variable in AutoCAD (introduced around 2020-2021) specifies a default layer for new text and multiline text objects, allowing them to be placed on a specific layer regardless of the current active layer.
Thanks!
  • TEXTLAYER variable is not implemented in BricsCAD yet, I'm not sure if there is another way to set default layer for Text /Mtext.
  • In amongst Lee Mac's treasure trove of Autolisp goodies is this little gem.
    https://www.lee-mac.com/layerdirector.html
  • You can redefine say TEXT command in a lisp defun so 1st line in the defun is set the layer name, then (command "TEXT") you can ignore the redefine by typing "._text" For me I would have like Text1, Text2 and so on so Text can be on various layers, not just locked to one.
    (defun c:TEXT1 ( / )
    (setvar 'clayer "TEXT1")
    (command-s "TEXT")
  • thank you all!
    Layer director is what I was searching for,
    until TEXTLAYER is implemented natively by BricsCAD
  • Try using toolpallet
    WORKS
