making a dtm area smaller
In Civil-3D I can use border lines to reduce the area of a dtm that uses a asci file. How can I do it in Bricscad?
  • Hi Biene,
    You can add a boundary to any TIN Surface to limit the area. All you need is a polyline. Just go to the Civil Explorer and find your Surface. Right click on it and select add then add boundary.
