unable to unload multiple xrefs
hi
I got a problem with unload multiple xrefs in attachments panel;
when I select few of them , right click with mouse and select "Unload" only one of selected unloads and the rest stays loaded;
Bricscad v26
there is no problem with this file on other workstation, having Bricscad v25
  • Yes, I can reproduce this also, in V26 and V25. Only in V24 or probably earlier V25 (I checked V25.2.09) it worked as expected. There is a task to correct the behavior of Attachments panel, at the moment all xrefs can be unloaded at once via Drawing Explorer.
