impossible find intersections
for BricsCAD for linux, anyone how to use "inters" " vla-IntersectWith" but not luck, always detect intersections in coordinates 0,0,0
anyone can share any sample to find intersection with Curve objects, or polylines with Cuved segments, or splines?
attached the autolisp to migrate to bricscad
0 -
The attached LISP works for me in BricsCAD in Windows. From the developer help both "inters" and " vla-IntersectWith" should be available on linux.
Maybe check out these examples from Lee Mac
If these don't work for you, then I suggest you raise a support request to get it investigated.
Jason Bourhill
CAD Concepts Ltd
1 -
Maybe try this also by CAB.
1 -
That looks to be an earlier version to the one from the OP. The updated one has a check for BricsCAD, which in turn sets the name of the hatch pattern file.
http://www.theswamp.org/index.php?topic=10370.0
Jason Bourhill
CAD Concepts Ltd
1 -
I found an error in your lisp.
… anyway, thank you.0 -
lee mac code use VLA-intersectwith, and have same problem, intersections are detected in 0,0,0.
This problem need be fixed by BricsCAD
here a sample:0 -
well with last update, intersectwith was fixed, probably because this post, thanks
0
