Story elevation in Python
Hi guys,
please how can I get Story Elevation from the Spatial Locations Manager?
Thank you.
  • I am a newbie in LISP/Python programming. So is there a possibility to integrate LISP commands into Python script?
    Thanks
  • Hello.
    Bricscad doesn't include a Python API.
    The only python functionalities are the ones provided by the BIMPYTHON command.
    More details about this can be found in the article linked below.
    https://help.bricsys.com/en-us/document/bricscad-bim/building-data/using-python-scripts?version=V26&id=165079159510
    Concerning using lisp, you could experiment using the BIM LISP API.
    The link below leads to a web page containing more details about this.
    https://developer.bricsys.com/bricscad/help/en_US/CurVer/DevRef/source/BricsCADBIMLISPAPI.htm
    A very basic example, related to the topic of this post, is like this:
    <pre>
    (vl-load-bim)
    (defun fn_elevations (/ bldgs bldg stories story elev)
    (setq bldgs (bim:get-all-buildings))
    (foreach bldg bldgs
    (princ (strcat "\n" bldg " :"))
    (setq stories (bim:get-all-stories bldg))
    (foreach story stories
    (setq elev (bim:get-story-elevation bldg story))
    (princ (strcat "\n" story "\t\t - " (rtos elev 2 2)))
    (princ "\n\n")
    (princ)
    </pre>
    This will list buildings, floors, and elevations at the command prompt.
  • Its_Alive
    edited March 14
    Does Bricsys have a good sample drawing I can use for unit testing
    edit… i found one
  • Thank you. I need it in a more complex code, so maybe I will try to do it in NET.
  • Its_Alive
    edited March 16
    You can use Python, if you can get PyRx to load, https://github.com/CEXT-Dan/PyRx
    it’s more of a DIY, I wrapped some of BRX BIM, maybe it's enough
    import traceback
    from pyrx import Ap, Db, Ge, Bim
    @Ap.Command()
    def doit():
        try:
            db = Db.curDb()
            for building in Bim.BimBuilding.allObjectBuildings(db):
                for story in building.allObjectStories():
                    print(f"{building.name()}, {story.name()}, {story.elevation():.2f}")
        except Exception as err:
            traceback.print_exception(err)
    Main Building, Floor 0, 0.00
    Main Building, Floor 1, 3250.00
    Main Building, Floor 2, 6500.00
