TXT2MTEXT not working properly
As far as I know, I should be able to use TXT2MTEXT to combine multiple Text elements into one Mtext element. I have set the settings to sort from the top, but it decides to sort it different from what it's set up to do.
In this example I am combining 4 text elements into 1 Mtext element, but the order is all mixed up, I am trying to make sense of why it do what it does.
Am I doing it wrong?
0
Just found out it it sorting by the X-axis instead of the texts position on the Y-axis, but why?
0 -
Interesting to see there’s a sort since there’s both numerical and Lexicographical, 1, 2, 10, 20 vs 1, 10, 2, 20
edit DOH, it's by Y
0
